SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 06/30/2007
digiblur
14,190
4
Louisiana
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 06/30/2007 - 56 changes
Uplink Comparison Range: 06/27/2007 02:26P - 06/27/2007 03:41P -
137 - QVC [MPEG2 SD] added to EchoStar7 119W TP 11 ConUS beam (Available)
377 - FOXCN [MPEG4 HD] added to EchoStar5 129W TP 08 ConUS beam (Not Available)
378 - FOXPT [MPEG4 HD] added to EchoStar5 129W TP 08 ConUS beam (Not Available)
378 - FOXPT [MPEG4 HD] added to EchoStar3 61.5W TP 30 ConUS beam (Not Available)
380 - FOXD [MPEG4 HD] added to EchoStar5 129W TP 08 ConUS beam (Not Available)
381 - STO [MPEG4 HD] added to EchoStar5 129W TP 08 ConUS beam (Not Available)
406 - STNTA [MPEG2 SD] added to EchoStar8 110W TP 06 ConUS beam (Not Available)
574 - FPCHN [MPEG2 SD] - EchoStar1 148W TP 27 ConUS beam changed to Not Available
574 - FPCHN [MPEG2 SD] - EchoStar3 61.5W TP 16 ConUS beam changed to Not Available
575 - FPCHN [MPEG2 SD] - EchoStar1 148W TP 03 ConUS beam changed to Not Available
575 - FPCHN [MPEG2 SD] - EchoStar3 61.5W TP 10 ConUS beam changed to Not Available
5501 - TNTHD renamed to TNT (A)
5505 - ESPHD renamed to ESPN (A)
5506 - ES2HD renamed to ESPN2 (A)
5507 - NFLHD renamed to NFL (A)
5515 - HBOHD renamed to HBO (A)
5516 - SHOHD renamed to SHO-E (A)
5692 - KTNL1 (NA) removed from EchoStar2 148W TP 14 ConUS beam
5693 - KTNL2 (NA) removed from EchoStar2 148W TP 14 ConUS beam
5711 - TEMP1 [MPEG2 SD] added to EchoStar8 110W TP 17 ConUS beam (Not Available)
5712 - TEMP2 [MPEG2 SD] added to EchoStar8 110W TP 17 ConUS beam (Not Available)
6495 - WJSU [MPEG4 HD] added to EchoStar7 119W TP 09 Deep South beam (Not Available)
6496 - WIAT [MPEG4 HD] added to EchoStar7 119W TP 09 Deep South beam (Not Available)
6497 - WVTM [MPEG4 HD] added to EchoStar7 119W TP 09 Deep South beam (Not Available)
6498 - WBRC [MPEG4 HD] added to EchoStar7 119W TP 09 Deep South beam (Not Available)
7124 - KPAX2 [MPEG2 SD] - EchoStar10 110W TP 31 Spotbeam 37 changed to Available
8683 - WWAY [MPEG2 SD] added to EchoStar10 110W TP 29 Spotbeam 02(NC,SC,VA) (Not Available)
8684 - WILM [MPEG2 SD] added to EchoStar10 110W TP 29 Spotbeam 02(NC,SC,VA) (Not Available)
8685 - WECT [MPEG2 SD] added to EchoStar10 110W TP 27 Spotbeam 02(NC,SC,VA) (Not Available)
8686 - WSFX [MPEG2 SD] added to EchoStar10 110W TP 27 Spotbeam 02(NC,SC,VA) (Not Available)
8687 - WUNJ [MPEG2 SD] added to EchoStar10 110W TP 27 Spotbeam 02(NC,SC,VA) (Not Available)
9420 - TNTHD renamed to TNT (A)
9424 - ESPHD renamed to ESPN (A)
9425 - ES2HD renamed to ESPN2 (A)
9426 - NFLHD renamed to NFL (A)
9429 - NTGHD renamed to NTGEO (A)
9430 - SHOHD renamed to SHO-E (A)
9435 - STZHD renamed to STARZ (A)
9440 - HBOHD renamed to HBO (A)
9456 - HBOHD renamed to HBO (A)
9460 - SHOHD renamed to SHO-E (A)
9461 - HGHD renamed to HGTV (A)
14516 - KDEV3 (NA) removed from EchoStar1 148W TP 21 ConUS beam
14517 - KDEV4 (NA) removed from EchoStar1 148W TP 21 ConUS beam
14518 - KDEV5 (NA) removed from EchoStar1 148W TP 21 ConUS beam
14631 - KSCI3 (NA) removed from EchoStar7 119W TP 01 South California beam
19053 - TSN (NA) removed from EchoStar8 110W TP 14 ConUS beam
36854 - DNL10 moved from EchoStar1 148W TP 19 ConUS beam to EchoStar9 121W TP 21 ConUS beam (A)
36854 - DNL10 moved from EchoStar3 61.5W TP 29 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A)
36854 - DNL10 [(0X8F)] added to EchoStar3 61.5W TP 29 ConUS beam (Available)
Transponder Changes:
EchoStar8 110W TP 17 ConUS beam QPSK added to tables
Channels in the system: 4246
(A) = Available to subscribers
(NA) = Not Available
Accidentally overlooked these as I have them filtered out since they move all the time:
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 06/30/2007 - 15 changes
Uplink Comparison Range: 06/27/2007 11:53A - 06/27/2007 05:39P -
625 - MLB (NA) removed from EchoStar7 119W TP 10 ConUS beam
626 - MLB (NA) removed from EchoStar7 119W TP 12 ConUS beam
627 - MLB (NA) removed from EchoStar8 110W TP 24 ConUS beam
628 - MLB (NA) removed from EchoStar7 119W TP 18 ConUS beam
629 - MLB (NA) removed from EchoStar7 119W TP 21 ConUS beam
630 - MLB (NA) removed from EchoStar7 119W TP 21 ConUS beam
631 - MLB (NA) removed from EchoStar7 119W TP 10 ConUS beam
632 - MLB (NA) removed from EchoStar7 119W TP 18 ConUS beam
633 - MLB (NA) removed from EchoStar7 119W TP 18 ConUS beam
634 - MLB (NA) removed from EchoStar8 110W TP 24 ConUS beam
635 - MLB (NA) removed from EchoStar8 110W TP 16 ConUS beam
636 - MLB (NA) removed from EchoStar7 119W TP 18 ConUS beam
637 - MLB (NA) removed from EchoStar7 119W TP 12 ConUS beam
638 - MLB (NA) removed from EchoStar7 119W TP 10 ConUS beam
639 - MLB (NA) removed from EchoStar7 119W TP 10 ConUS beam
Updated PDFs. One is sorted by channel number and the other is sorted by satellite/beam so you can see the TP loading.
  • DishNet2007.06.28-ByChannel.pdf
  • DishNet2007.06.28-ByBeam.pdf
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 06/30/2007 - 1 change
Uplink Comparison Range: 06/28/2007 11:08P - 06/29/2007 07:55A -
360 - ALTUD moved from EchoStar5 129W TP 08 ConUS beam to EchoStar5 129W TP 27 ConUS beam (NA)
