Signal Strength
Chris36
448
4
Rhode Island
I have EA and 118.7 and a 722k. Here is my signal strengths I'm in Rhode Island. I had a little better strength before should I repoint my dishes?? And is it normal for the signal to go up a few degrees at night then drop during the day?? I remember the numbers were up 8 points before on most of the satellites. So maybe the wind moved it a bit. Been up since May.
61.5
Transponders 1 21
2 45
3 77
4 61
5 78
6 46
7 23
8 62
9 53
10 46
11 48
12 59
13 52
14 50
15 18
16 59
72.7
Transponders 1 59
3 63
5 55
6 54
7 61
9 57
11 58
13 58
15 62
16 61
77
Transponder 1 51
2 40
4 44
5 50
6 41
8 45
9 50
10 37
12 45
13 50
14 37
118
Transponder 1 55
2 58
3 54
4 59
5 63
6 64
7 54
8 57
9 56
10 62
11 53
Thanks,
Chris
The signals seem pretty average. Go into system info (6,1,3), wait for it to test 100 percent and see if it gives you a message in red at the top. If you are losing signal during the day you may have a heat issue in the cabling or LNB
I chatted online with Tech they said that's normal with the signal strength I don't think it is. Don't know if the guy was new or didn't know what he was during. I said we get alot of wind and it could of moved the dish a bit. I wanted someone to come out and check it out.
