I have a Pansat 3500 which works great and also a Fortec Mercury II which also works great. The pansat can move the polarity in the LNB but not the Mercury.
That is why I wanted to experiment between the 2.
I have a diseq 4 ports connected to the Pansat 3500. I then connected a cable from the IF OUtput in the pansat into the Satellite-In in the Mercury, but can not get any signal in the mercury. I connected the Mercury to the tv via coax and the pansat into the tv via component cables, so I get the Mercury in channel 3 and the pansat in AUX.
What else do I need to do to move the signal from the Pansat to the Mercury?
Do I need to also make the same port setting (diseq) in the mercury as I have them in the Pansat?
Thanks.
Thanks.
