Some details on the 622 from the Tech Portal
Looks like an HDMI cable is included along with an HDMI/DVI adapter. Wonder if this is really the case. I thought I read in the 211 posts that no HDMI cable was included.
Paradox-SJ said:
Look like the 942...with some additionl search features and Dish on demand screen...Now lets just hope it is as stable as the 942
That's the bottom line: stability. I'll wait for a couple of guinea pigs (some of you :D) before I bite.
The 942 included an HDMI cable.
I think the 622 will be alright stability wise being that it is built off the 942. I think Dish has finally found a good base to work from. The 211 I have has not had one issue since I got it (looks like my 522 interface). I am looking forward to getting my 622 to replace the 522.
I know it might seem trivial, but the best thing I like about the 211 is the widescreen guide and extended hours on the guide. I also really like the font they used for the banners. Just nice and clean.
Oh yeah, it did NOT come with any component cables, Just coax, phone, and composite.
Am I correct in assuming you only receive 1 UHF remote. In other words...the room the 622 is sitting in, you must have a clear shot of the 622 to control it. No behind cabinet doors?
That stinks. My 6000, 811 & 4900 all had uhf remotes.
In Dish's recent facts blast they talk about current customers paying $299 for 622 upgrade & commitment but don't mention dish 1000 upgrade. They also make it seem like the 622 is available 2.1.06.
Any input on availability?
All of the Dish dual-output receivers come with exactly one UHF/IR and one IR remote.
ebay is full of 6.0 UHF Pro remotes and I am pretty sure those can be configured to control either TV1 or TV2 on a 622.
How to feed the TV2 RF output over coaxial cable to your second (bedroom) TV?
Do I need an optional modulator?
Do I need optinal a modulator?
No you don't. You will use the "Home Distribution" RF connection (yellow). It uses channels 21-69 to distribute the signal to TV2.
Thanks RandallA. Do you know if "Home Distribution" RF connection (Coax) can be mixed with regular cable channels by using cable splitter, since I am using cable for locals? Can I select any of those 21-69 channels to use on my choice? :confused:
RandallA said:
I just found the 622 receiver now being listed in the Tech Portal:
http://rweb.echostar.com/departmental_content/TechPortal/content/tech/receiver/622.shtml
I like the Interactive menus.
Is there a reason why I can't get the Tech Portal page to load correctly? Do I have to be a retailer to access the whole shebang? All I get is a jumble of stuff on the left side of the page. Info layered on top of one another. When I click on "home" I get the primary access , but when I choose DP-622, it goes to the stuff I just mentioned.
Just curious. Thanks:
Lyle
No, you don't have to be a retailer. Anyone can access it. It did that to me before when I tried it with Firefox before. What browser are you using? Try it with IE and see if the same thing happens.
In theory, yes you can but I wouldn't do it because both frequencies CATV and the output of the 622 will be fighting each other. You'll probably get neither one of them. You could try a channel that's not being used in your cable system but most likely they are all used.
New Dish customers read these existing customer posts
522 search question
