Starchoice Dish to get E*
thesmith7
26
I have a spare Starchoice Dish, If i Switch out the lnb to a E* can i use the Satchoice dish to pick up 119 and 110?
You can easily pickup one or the other. In order to pickup two at the same time you would need to make the dish have a skew (if they do not have one already) and make a special bracket to hold the lnbf's / twin.
An adapter called a Flexi-block will work. I use one with a *C 75 cm elliptical dish. It takes some patience to set it up but it does work well. It should be possible to build a similar adapter.
Dish Network DVR Model 510 work for BEV?
