Std-Def feed gone?
alleykat26
10
Just started receiving the hi-def satellite channels for the Dallas area. When I tune to what were the std def channels 4-00, 5-00, 8-00 and 11-00 I can only get the "hi-def" feed coming thru and not the std-def feed (although it is std-def feed on my 501's).
Can I no longer get the std-def feed on my 622?
you'd have to change the map down priority to SD, but why would you want to do that?
you can also get the sd by directly entering their number as well...
The 622 is set for HD Priority so to map down the HD channels which also appear at 6383-6386. The sd channels will still be located at 8400-8416.
622 installation problems
Problem with signal since move to Echo X
