I switched to dish network about 10 years ago and I set up my first system myself with little problem. The system was a standard system.
After a few years, a windstorm downed a tree that crushed the disk (and part of my house) so since insurance was fixing everything I upgraded my dish and smart card to the 500. The dish 500 has 2 LNB’s (one for 110 and one for 119 digital running into a switch) I stopped dish network service in 2004 and switched back to cable so I could have high speed internet. I never took the dish down but I did bump it with a latter once that moved it just a bit.
Well I wanted to switch back to dish and a friend of mine just cancelled his service and gave me a DP301 receiver with card to use with my dish 500. So I called Dish Net and transferred all the equipment over to me
I hooked up the receiver and have no signal, I wasn’t surprised. I checked the dish specs in the receiver and for birds 119 and 110 at my zip they are
ZIP CODE 49234:
AZ 226
EL 32
SK 119
I went out and readjusted the dish, still no signal. I double checked all my connections and cleaned them. Still no signal.
I called dish net tech support and went over everything. They had me run “check switch” and it came up with a warning and the tech help said my switch failed and that I should check my connections and replace the switch. Now I HATE just parts swapping to “try” to fix a problem so I asked the tech if I could bypass the switch and connect direct to one of the LNB’s to see if I get a signal. After about 10 seconds of silence the tech said “oh that would be a good way to see if it was the switch”. Anyway that ended the call.
I went back to the dish and ran a NEW cable to the 110 LNB and still no signal.
I then hooked to the 119 LNB….no signal.
I loosened the bolts and rotated the dish about 10 degrees in each direction and still no signal.
I ran check switch connected to the LNB and it failed…….
So my questions are;
I need some help as the wife is loosing confidence in me…..LOL
ZIP CODE 49234:
AZ 226
EL 32
SK 119
- How likely is it that both my LNB’s are bad after sitting for 4 years?
- Does check switch check for a signal or does it run a diagnostic that checks for proper connection of the LNB’s?
- Can I check the switch by splicing it in line to a VCR or something?
- What should my next steps be? Buy a new LNB and look for a signal?
