swm 16 install question
OSD771
256
Pokey
Instead of using a 16 switch on this install could I use two 8 way switches?
Its a swm install.
I am essentially trying to avoid buying a 16 switch
Ah I did some research and found that. Thanks hutch!
So if I were to use a regular 4 port lnb, would I still use swm switches?
And would I have to run two lines to each dvr?
You can cascade SWM8 switches with no problem. The only reason you would want a SWM16 is if you are using multiroom viewing and want to share between enough boxes that go over 8 tuners.
That said, SWM16 are getting cheaper on ebay, and are probably about the same as buying two SWM8's.
I think he was referring to an actual 8 way SWM splitter.
As for using the 4 output LNB, you would need two 6X8's and 4 ALL power pass splitters
A new SWM16 is $60 shipped on ebay by multiple sellers, power supply and splitters included. No reason shortcutting at that price.
Olympics on Directv
HR34 Software Release v.054C 6/7/12
