Test Patterns
smjbh5
414
5
SF Bay Area
Do any of you know which channel broadcast test patterns. I want to use them to calibrate my satellite input on my TV.
I have the DVE blu ray disc, but thats for the BD player input. Don't want to use it cause it's a different source and signals come across different on satellite and BD.
HDNet Test Patterns
Sat., Nov. 29th 7:30 AM ET HDNet Test Patterns - Wonder how your home theatre is doing? Wish you had test patterns to help set it up? Well, HDNet is here to help. This short program will help you get the most out of your home theatre setup by providing you with the same professional test patterns HDNet uses to set their gear.
HDNet Original Programming - HDNet Original Programs
Want a good way to see how bad your TV's overscan is? View the final test pattern and press the remote's position button to do PIP side by side. You will then see the entire pattern in the PIP and can compare it to what you see full screen.
Florida Panthers Not on Dish
322 wont work with phone line
