True south sat
Baps
4
Hi Is there any one can help me, which one is true south sat in montreal?
Latitude: 45'5 N
Longitude: 73'6 W
please i don't know how to calculate :(
Thank you ice burg, so I have to point my dish with motor at sbs/6 with envacom lnb , by the way I,m using pansat 250SM and how i will know i got the right bird
thanx quert I have Invacom quad DSS/FSS 0.3db but on sbs/6 ihave only one transponder that is 11741H 6616
The 11741 transponder is no longer active, use the new one I gave you, I have a Pansat 2700 and 3500, this is how you edit a transponder if it is same for the 250.
Go into the menu
select "Install"
select "Edit TP/Satellite"
Select the correct satellite "SBS6"
select "Edit TP"
Select "New"
Enter the new information or you could select the old transponder and edit it.
ONN is the only allways on tp Ive seen on 74.0w but I tell ya latley its been one of the more interesting satellites for feeds, tonight alone I saw two sports HD feeds and one analog feed. its got a bit of everything on it and lots of activity.
Remember to let the motor move via USALS when you select SBS-6 BEFORE you tweak the dish for proper aim. That way, once you get SBS-6 tweaked, you'll be on the arc :)
Thank you iceberg and all others its works like i cant explain. its really cool
New computer will I need any special codecs?
Sports on FTA
