USB Drive Recommendation?
hossebuck
On Vacation
27
Hampton, Ga. 30228
Iceberg:
Saw on one of your post about you having a 500gb external hd. Do you power the external drive through the usb port or does the microhd have power to the port? Reason- I purchased a toshiba 500gb external hd today to use on the microhd.
hoss e buck
if you buy an external hd get the one that has its own power supply not the one that powered via usb (only)
these are usually larger ( size not capacity ) the small sized ones are usually usb powered
I tried a usb powered laptop drive, and there was some sort of issue. I believe that was because the receiver doesn't have enough usb power to run most drives. I now have a self powered (with wall-wart) Western Digital "Deskbook 750gb" drive, and it works perfectly. This drive even goes to sleep when not used, and the microHD properly wakes it up and records with it. I usually start my recordings 1 minute early, as it takes about 15~ seconds to wake it up. If I ever get close to filling it, there will be so much to watch that I'd never have time to do so!
Rotation Resolution?
MicroHD Blind Scanning
