Using DVR 625 On One TV
MGradiz
I have my DVR 625 connected to one TV. I have both TV1 and TV2 connected to my TV.
However, I have no control of my TV2 connection...My second remote for the receiver is not programmed....Is there a way to program it or allow my first remote to control both TV1 and TV2...?
Press the mode button on the front of the receiver to change to 'Single Mode'. You will continue to use the remote you use now. You can also disconnect the tv2 connection from your set. When in 'Single Mode', tv2 output is same as tv1.
You can also use the "PIP", "SWAP" and "POSITION" buttons on your remote in single mode for the picture in picture feature. This is ONLY available in single and NOT dual mode. This will allow you to watch one program while having another in a small window overlayed on top of your current channel. You can also record a program while watching another without having to be on the channel you are recording.
Little Rock HD Locals??
Why DISH Is Doing So Poorly (Rant Inside)
