VIP 722K Home Distribution Issue
ssatellite
Indiana
TV1 and TV2 on Home Distribution coax output do not show any signal regardless of Air or Cable or channel settings, but the dedicated TV1 works on either Channel 3 or 4. Is this likely a failure of both TV/Cable modulators or? I am not seeing any loss of signal, and recording on both tuners works. My Home Distribution output is direct to a single TV, not through a splitter.
If TV 1 is set up with either an HDMI or RCA cables, the TV output in the modulator setup screen in the menu for TV 1 should be set to off and then TV 2 would be set to either generally 60 or 73.
Or are you saying that TV 1 is also hooked up using a coax?
In the Home Distribution you can have TV 1 multiplexed with TV 2, with UHF or cable channels chosen independently, and there is the option to turn TV 1 off. There is in addition a seperate VHF (channel 3 or 4) mirror of TV 1 also multiplexed without an option to turn it off. The usual arrangement is to use a splitter to feed seperate SD TV1 and TV2 via UHF , and possibly TV 1 via VHF. I am only using TV2 without a splitter. However, no combination of settings produces any TV1 or TV2 output on UHF or cable channels, but the TV1 mirror is present and good quality on channel 3 or 4 selectable. It seems odd that both TV1 and TV2 UHF modulators would fail but maybe so. Wonder if anyone else has seen this.
Refurbished Hopper 3's
Sorry to ruin your day with this!
