What do I need to to make my 721 work along with my 3 other receivers?
NpaulTodd
1,368
Fresh out of Prison !!!!!!!!!!!!
Ok here is what I have A dish 500 ( legacy) (119 &110) running into a SW44 switch and 3 receivers hooked up to 3 of the 4 outputs on the Sw44 since the 721 is dual tunner I will need to run 2 more cables from the Sw44 switch but there's only 1 output left , so what do I need to add that 5th line , will a splitter work , if so what kind , Or do I need to but another Switch , Please keep in mind I need the cheapest route possible , Also if you know a place that sells what i need please let me know :)
Welcome aboard!
You're between a rock and a hard place. You need a (very complicated to setup) second Legacy switch, or a DishPro conversion which is an issue if you have Legacy (4-digit model number) receivers.
If retiring one of the existing receivers is not possible, then by FAR the cheapest, simplest thing to do is mount a second Dish500. Yeah, really.
MPEG4: Why assume the worst case scenario?
Easy 522 Questions - Maybe
