What is a feed horn?
I gotta tell you… I've been running this blog for a long time and yet I don't think I'll ever run out of funny-sounding terms to define. Some of them sound so improbable that you have to wonder.
Like, "feed horn."
I'm not sure what you came into this article thinking a "feed horn" is, but it's a fun-sounding word that can conjure up all sorts of images. In truth, it's really not that exciting. It is, however, an important part of a satellite dish. In order to understand a feed horn, you have to understand how a satellite dish works.
It's just a way to focus signals.
A satellite dish is an antenna that's designed to pick up very, very, very high frequencies. There are two really distinguishing things about satellite transmissions. First of all, by the time they get to you they're very weak. No surprise, since it took them over 20,000 miles to get to you. Second, since the wavelength of a signal gets smaller as the frequency gets higher, those waves are reaaaaalllly small. Like, they're around a millimeter in size.
So, one more thing about that. The smaller the wave, the smaller the perfect antenna for that wave. So in reality, a satellite antenna is about the size of your pinky nail. I'm sure this makes zero sense since a satellite dish itself is much bigger than that.
The big round "dishy" part of a satellite dish is called the "reflector" and what it does is focus all those waves like a lens.
It focuses all of them on a point in front, where the LNB goes.
The LNB? What?
An LNB is a complex little computer that does an amazing amount of work. It consists of four parts:
  • The receiving antenna, where the satellite signals come in;
  • a Low-Noise amplifier, which bumps up the signal power so it can travel over a wire;
  • a Block downconverter, which takes the higher frequency signals which don't travel well on wires and converts them to lower frequency signals that do;
  • The feed horn, which is the subject of this article.
LNBs make satellite reception possible. Once all that signal is focused in one place, it's still not strong enough to go down a wire in its current form. The LNB takes care of that.
Finally, the feed horn
Even though the dish does a pretty good job of focusing the signal, it doesn't do a perfect job. That's the job of the feed horn.
A feed horn looks sort of like a funnel. It helps move those signals down the line and concentrates them even further so they land in precisely the right place. The one you see above you is just a typical one I found on the internet.
The feed horn in a satellite system is behind that part on the LNB that's covered in white plastic. The plastic is invisible to satellite signals and serves to protect the electronics inside. The actual feed horn is behind the white plastic cap. If you look at the image below of a DIRECTV LNB, it's the thing that sticks out in the middle.
This particular feed horn is oversized so it can focus the signal on three separate receiving antennas. You can see that when you look at the top view.
Need a new satellite dish?
If you're looking for satellite accessories or any satellite TV parts, check out the great selection at SolidSignal.com. We have all the same items that you'll find on DIRECTV and DISH installer trucks, all at a great price. If you're not sure what you need, call us! The experts are here for you during East Coast business hours at 888-233-7563. If it's after hours, just fill out the form below. We'll get right back to you!
The post What is a feed horn? appeared first on The Solid Signal Blog.
Continue reading...
HEY BAR OWNERS: Do you know who your DIRECTV rep is?
Are mechanical hard drives dead?
