Where to install an antenna, suggestions please.
Go to www.tvfool.com and find out what you need for an antenna. I used 92334 for Fontanna and it shows you have ABC and an INDY as VHF channels that are line of sight. Put up a HBU33 antenna on the chimney. The C2 dosen't receive VHF channels.
I looked at TVfool and if you are in the southern part of Fontana near I-10 the signals are strong. So you could probably mount it in the attic. If you are in the north closer to 210 then it will need to be outside because the terrain starts block you from direct LOS to the signals. North of 210 and you would need a much larger antenna to get anything.
Me TV Coming to Washington DC
Need some advice on Antenna set up please
