RE: [VOOM] Re: Wilt - Are solutions to technical problems ever coming?
Fwiw, I have time warner cable and they have the same volume issues. If I'm
watching an hd channel and switch to a non hd channel, the volume increases
by atleast 20db.
Robert
_____
Sent: Monday, February 28, 2005 8:07 AM
To:
VOOM@yahoogroups.com
Subject: Re: [VOOM] Re: Wilt - Are solutions to technical problems ever
coming?
Philhu,
There were actually four questions so your numbering system is confusing.
Which question are you answering with number 1? Volume level
inconsistencies or direct entry of sub channels because I am not sure how to
"fix" either one.
Question 3-The sparklies that I've seen on the weather channel, headline
news, history channel, etc. I believe are a direct result of using C Band
analog feeds that exhibit the same problem, not digital feeds. I have a BUD
and when the sparklies are bad on VOOM on those channels they are more
noticeable on my C Band BUD. Atmospheric conditions have an effect on this.
Unless you work for VOOM and are in a position to know for sure, the answer
to the OTA question is elusive at best. Some people have disconnect Rainbow
1 and had OTA for months, others experience the 2 week effect you describe.
I believe this could be change via a satellite software download if vOOM
ever decided to change their policy. I still maintain that if you own your
receiver they really are in potential violation of FCC policy by restricting
your ability to receive OTA locals. If you are leasing then I can
understand the policy. Until someone legally challenges this the policy
will probably not change unless VOOM is going under in some fashion.
Frankly, it's easier to just go buy a good OTA STB then worry about this one
or consider getting a lawyer.....$200 gets you a great STB.
thegrod
----- Original Message -----
To: <VOOM@yahoogroups.com>
Sent: Monday, February 28, 2005 5:42 AM
Subject: [VOOM] Re: Wilt - Are solutions to technical problems ever coming?
> #1, yes you can. It has been explained here a few times. Search for
> the answer in this forum. It has been explained.
> #2, sparklies - don't know. It is caused by over modulation of signal
> or mistuned c-band rcving system for analog, and since I am sure they
> are grabbing a digital signal, it is most likely overmodulation,
> probably at the rcving sat station end. I used to get these alot with
> a 10 foot c-band/ku-band dish years ago.
> #3, No they will not. the ota only works on a subbed box. Try taking
> your box off the sat cable for 2 or so weeks, it loses all
> authorizations, incl ability to get ota.
> I tried when I moved. Case closed on OTA.
> philhu, Posted this message at http://www.SatelliteGuys.US
> Yahoo! Groups Links
Yahoo! Groups Sponsor
ADVERTISEMENT
http://us.ard.yahoo.com/SIG=129v7fu84/M=298184.6018725.7038619.3001176/D=gr
oups/S=1705036932:HM/EXP=1109686028/A=2593423/R=0/SIG=11el9gslf/*
http://www.
netflix.com/Default?mqso=60190075> click here
http://us.adserver.yahoo.com/l?M=298184.6018725.7038619.3001176/D=groups/S=
:HM/A=2593423/rand=244582600>
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
* To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
[Non-text portions of this message have been removed]
