Xtreme II 0.3 dB LNBF
PSB
On vacation
3
5
Just done a side by side comparison test with the new 0.3dB Xtreme LNBF and my Invacom QPH-031
VERY IMPRESSED! :shocked
Checked the below satellites and transponders and there was little or no difference between the two LNBF on EVERY satellite and TP. I tried!
The Bottom line this is a fantastic LNBF for the price and performed EXACTLY the same as the much more costly Invacom.
Point for point on signal quality!
IA-6
News 1 Live Signal Quality 75%
University Network 82%
G10R
The Tube 60%
11800 TP. 85%
SBS6
ONN 74%
Pas 9
Cubavision 82%
(A Universal LNBF was used to find/store this channel will then work with standard LNBF)
Pas 3R
11960 90%
Unlike the regular Xtreme LNBF this model is all steel and has to be off set from the usual LNBF scew position. (see below)
Installing the Xtreme II LNBF
Its a Standard US Ku (10750 L.O.) Light weight compared to the QPH-031
40mm throat mount.
With the all metal housing it should have better shielding, better performance and less interference.
Nice little unit!
This side by side test was performed on a 36" offset dish!
Specs.
Input Frequency 11.7~12.2 GHz
Output Frequency 950~1450 MHz
Noise Figure 0.3 dB typ.
Gain 62~66 dB
Gain Ripple <5 dB typ.
Local Oscillator Frequency 10.750 GHz
Local Oscillator Phase Noise (typ) 1 KHz -65 dBc/Hz
10 KHz -95 dBc/Hz
100 KHz -110 dBc/Hz
Local Oscillator Stability +/- 1 MHz
Current Consumption < 100 mA
Image Rejection > 40 dB
Horn Type Offset
F/D Ratio 0.5 ~ 0.7
Cross Pol Isolation > 20 dB
Image Rejection 45 dB (min.)
Output VSWR 2.5:1 (max.)
Output Connector 75 ohm F type female
Operation Voltage 11.5 ~ 14.0 V for Vertical
16.0 ~ 19.0 V for Horizontal
Operating Temperature -40ºC ~ +60ºC
I just bought 2 of these from Pete. I am very happy with my lnbf's. One is for SBS 6 and the other for AMC 9.
On AMC 9, Primestar dish reading with Primestar lnb was in the low 70's on the NBC transponders. 82 on DirecWay signal 12160H/SR 30000 at night
Fortec 100 cm dish
with Primestar lnb = 89 on DirecWay signal at night
.4 universal lnbf from Sadoun = 91 on DirecWay signal at night,
.3 Extreme lnbf from Pete = 95 on DirecWay signal at night and 90's on most of the NBC transponders.
On SBS 6 dish, with Primestar dish and lnb - ONN in the 70's, ABC New Orleans channel at 82, other New Orleans channel at 78 (nead 80 to get steady signal).
SBS 6 100 cm dish with .3 lnbf, all signals in the 90's for horizontal and vertical.
I just purchased this as it was the same price as the ASC-321 I was going to buy. On a scale of 1-10, how difficult would you estimate the mounting to be for a beginner?
Should be just as easy as ANY LNBF, just make sure you click above where it says "Installing Extreme II" As there is a small mark on the LNBF that has to be at the top.
9 out of 10.....
Rain fade on PBS
Need Help With Traxis Dbs 4500
