Back with DirecTV - some observations.
lparsons21
9,925
8,073
Herrin, IL 62948
I recently had my D* gear turned back on as I wean myself off of having both services. Been using the Hopper/SJ with Dish for quite a few months. Here's some observations, warts and all!
1. The first thing I noted was how much of a step backward the UI is on D*! I've said before that D* missed an ideal opportunity to make a really good UI when they brought out the Genie. Unfortunately they chose not to. The HD GUI is nothing more or less than the old text UI gussied up a little. And also so much wasted space on the screen while in the UI. The day of small screen, non-HD TVs is long gone. This needs a lot of work in the look and feel department.
2. Channels-I-Get - what a mess! It should be 'channels I can get if I want to pay more', because that is much more descriptive of what it actually is. And if all it did was make a fairly meaningless listing, it would be not so much of an issue. But it affects series links and such. I'm seeing lots of recordings of boxing shows on channels I do not get, which is just clutter that has no value. A couple years ago it was noted that D* was 'embarassed' about it, but it seems not enough to actually fix it!
3. 1.5 guide width - again, waste of space for no really good reason
4. EHD support = just a poor way to do it. No archiving, no using what is on it if you have to change out a DVR for any reason. This should have been changed years ago.
Now some good... :)
1. PQ is noticeably better on fast actions sports, not so much to my eyes otherwise. I like that.
2. Chronological listing of what's on a channel, I really like that, comes in very handy at times.
3. Show info - always did like that D* has the cast and info about them, like upcoming shows or which shows/movies a particular actor is in.
4. The Genie mini remote - I've learned to love it. Once you figger out the quirks it has, it is a really nice remote. Would be nice if it was really programmable, or at least allow for turning on/off an AVR but that's not a big deal to me.
I'd like to see a complete change in the UI's look and feel, but with AT&T buying D*, I'm not sure we'll ever see that. Currently the UI is very old and looks ancient compared to almost any other UI on a cable/sat box, or at least the ones I've seen.
Overall I'm OK with either service, and they both have the channels I watch in HD with the exception of Showtime Extreme being HD on Direct and only SD on Dish.
Reactions: whitewolf8214
ejb1980
3,406
586
Vermont
I have said it before and I will say it again - if Comcast can have a nice, fancy guide, Directv should be able to beat it! The best way to avoid the Channels I get mess is to use a favorites list and check off what you want. I have it set to get rid of all the PPV and shopping that's mixed into everything. That makes it 100% better.
lparsons21
9,925
8,073
Herrin, IL 62948
I have a couple custom lists.
But the bigger problem is that the CIG exists and series setups will set recordings to channels based on that bogus listing. For example, I have a Boolean search set for Boxing and it is now recording boxing on all the channels I actually do get, but it is also recording on channels I don't get.
Makes for a very cluttered listing of recordings. And it is nearly every day that these recordings are being made.
As to the UI itself, yes D* should have introduced an actual new UI for the Genie when it came out. That was the ideal moment to do that.
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,031
436
Central Michigan
I completely agree with you on what I consider my biggest disappointment with the UI - the 90 minute guide.
With most people using at least 42" TVs any more, there is no reason not to have an "option" for a 3 hour guide or comparable.
Would it take some work with the UI - sure - but it is fair to say there is no reason it couldn't be done without requiring a total overhaul.
maverick22
94
8
Dallas, TX
More people tend to agree with you than not as far as Direct's PQ for sports being better than Dish.
Dish's "laggy" Joeys as of late concerns me. I was thinking of switching from Uverse to Dish, but I think I'll just switch to Direct in a year. The RSNs in SD is a big concern to me as well.
Reactions: Soccernut
tigerfan33
7,241
582
Alabama
I came back from Dish because of the pq. I had both prior to 2010 for a few years but couldn't tell much difference. Then switched back to Dish after 4 years with Direct. Then came running back. Pq to my eyes is clearly better on Directv.
Blackloz
869
83
Minot,ND
I also use Custom guide setting. All the PPV, shopping channels,ect,ect are all unchecked. It makes it a lot neater looking.
Drucifer
920
111
NY Hudson Valley
Well, if AT&T does rebrand DirecTV, lets see how quick they change the logo.
And I'm one of their customer doesn't understand all the HD hype for the new guide, when hardly anything was done. Sort of reminded me of a snake oil sale -- all BS, no substance.
lparsons21
9,925
8,073
Herrin, IL 62948
Yeah, when I read the reviews and comments about the wonderful new HD GUI, and the hints before that about how great it was, when I finally got it on my HR24 I was very underwhelmed. Just the same old text interface gussied up a bit. And of course, the usual slowing down of things instead of the speed up all the fans brayed about.
Jimbo
Cutting Edge
Jul 14, 2005
68,869
7,222
NW Ohio - Buckeye Country
Well Uverse and Directv are going to be the same, how you get it might be different. One over sat, one over ATT's Network, but the experience will be the same when its all said and done.
I doubt that, if your refering to the Channel line up being the same, at least not for a long time.
lparsons21
9,925
8,073
Herrin, IL 62948
Well, for starters theres channels on one provider thats not on the other and vice versa.
Other than sports, the differences are trivial when it come to channel differences. Of course if the one channel you think is important is on one and not the other, then it is an issue.
For me, the channel differences of the channels I actually watch are practically non-existent.
