So it appears only HDNet Movies has movies without commercials. That sucks.
I can't believe how easy it is to skip past commercials in movies with a DVR and the 30 second skip ahead button. I wouldn't want to ever be without it.
EVERY movie I record (from well over 12 channels) on Absolute HD is viewed without watching the commercials, so I can stand watching then all.
If you'd like a list of the channels or a list of satellite receivers that have DVR's, let us know - and you too can watch movies without watching the commercials.
Plus I recorded scores of movies during the 3 month free-preview of HBO and Showtime that I've not all watched, and they don't have commercials.
Storyline interruptions and screaming commercials
Edited for time and content
Zoomed out from OAR format
No thanks.
Good for me is right. You must not have a mute button...You have to physically press the skip button, listen to a screaming commercial ofr one second before skipping again or backing up because you went too far, then listen to screaming commercials end in order to head back into a movie at the right point. It's very distracting and really messes up key moments in movies since that is where they like to insert commercials. Most channels that insert commercials ALSO cut movies in order to make them fit into very specific timeslots. This also disrupts a good storyline. Most channels that show movies also zoom out the picture to fit a 16x9 widescreen tv, ruining the original wider than 16x9 format of many movies.
No thanks.
You don't mind it, good for you.
Yes, that's what I said.A list of channels and dvrs???
There are many DVR's.DVR list? These days, if you are new to DVRs there is one, the 722.
No I didn't, the topic was movie channels, not HD capacity.You forgot to mention the external hard drive option as the internal drive on the dvr will fill up very quickly. I currently have 5
Yes no commercials to start with would be better, but this is a close second.
It sounds like you are using DTV, E*s DVR instantly advances 30 seconds without any sound or delay. As was said above, you can hit the button multiple times, w/o waiting. I usually hit mine (722K) 6 times, if I am still in a commercial, I hit it 2 more times, then one 10 second backup and there I am. Takes about 3 seconds all together.
Good for me is right. You must not have a mute button......
No I didn't, the topic was movie channels, not HD capacity.![]()
You said you recorded scores of movies...
That's not possible on a dvr unless you are using one of the obsolete SD models and you are recording downrezzed, pan and scan movies.
