HALLELUJAH!!!!!!Check out name based recording on OTA sub channels. Its fixed. S446 on the H2K.
For the "air next" issue, does it offer you the option to watch any other episodes in that folder before you even delete? I think that feature is better than what you want it to do. Far less steps now.
Because most customers do not have two Hoppers.
I have four HWSs and all have OTA. Just ran an OTA timer integration test and it did not work. The new timer went into the conflict mode to resolve. Also tested the integration feature with the satellite channels and it works. The conflict window #1332 that pops open does not allow selecting which Hopper to create the conflict timer.Anyone out there have two Hoppers and two OTA's? I'd like to know if the timer integration feature works with OTA.
They by no means list everything they fix.the change log looked weak
I've found that what it reports in DA can be lagged. I've had a newer version while DA still showed the previous version. Eventually it catches up...On Dish Anywhere, got to settings, then receivers. The software version is listed there.
