I am a registered used of TimeTrax (over 1-year now). I was using the old TimeTrax version and only today upraded to the Recast. I use XM PCR and everything worked well under the old version. Today, I get the upgrade and it continually kicks me off saying it has encountered a severe error. However, it only started this when I directed my firewall to block outgoing attempts. Then it started popping up continuous requests to go to the internet. After about 4-6 blocks, it errors out.
It was my understanding the software gets its information regarding channels, etc from the radio antenna and satellite, not from the internet. The computer only supplies a place to display what is playing and provides power for the unit. I have used the old software without an internet connection and that was how it worked. I travel and sometimes internet access is hit/miss or only dial up. That is why I went with the XM PCR. I could get XM music without the internet and without carrying a lot of equipment on the plane.
Has the requirement for internet access changed? I have it set, for now, to not check for upgrades, which was the only thing it should be going to the internet for.
Here is what I did:
I removed it from blocked applications.
Then I added it back with no permissions.
When I restarted the application, it asks for permission (via my firewall) to go to register1.timetraxtech (cannot post full URL because I do not have 5 posts and I am blocked from having a URL in my post). I blocked this.
I checked my registration and it states I am fully licensed.
When I block access, it malfunctions causing the software to shutdown and the music to continue. I am thinking, to prevent piracy, they want to verify a user is registered before allowing the software to work or it malfunctions. Just an uneducated guess. Until this is resolved, I will reload the older version.
If this is indeed the cause, it will be worthless to me when I travel because I rarely have internet access on the computer in the hotels.
NOTE: I went back to TimeTrax (not recast) 3.2 and with internet blocked it does not crash. Do not know if this is causing the crash, but it seemed to be the cause on my machine. If I allowed internet access (once) I had no problem.
