Sling Adapter not working with replacement 722k
jlamb30
Jun 19, 2007
17
Had to have a 722k replaced, and now the sling adapter will not work. It seems like the receiver needs to be web activated, but going through the online Web Activation process leads to a SQL error on the website. Support replaced the adapter... same thing. Adapter has the latest firmware, the light is on, and is Status: Ready. Broadband is fine... I can see the receiver on DishAnywhere, but cannot play recorded or live TV. Other than replacing the adapter, phone support has said they don't know what's going on... more than once.
HELP, please! :)
navychop
Member of the Month - July 2014!
60,071
27,392
Northern VA
I'm trying to remember if the ViP722 series had more than one USB port you could try.
In any event, it sounds more like a ViP722 problem than the adapter, which I presume worked previously. Does an EHD work?
dwarren2
4,076
287
Rochester, NY Region
When I had a 722, the adapter light would sometimes come on, other times not. Usually it would after the over night reboot. For Dish Anywhere, I highly recommend upgrading to the HWS. It's much more reliable. I never have a problem with DA now.
JayStil
597
27
USB can be a little wonky on the 722. I never could get my powered hub to work. Wanted to run a USB fan, SA and EHD all from the back port. Would refuse to recognize anything if the hub was plugged in. So I'm stuck using the front port for the EHD, and a cell phone plug-in block for the fan. Even then, my EHD isn't recognized half the time when plugged in.
jlamb30
Jun 19, 2007
17
I had already tried the front USB port, as well.
I really believe it's a receiver web activation issue. When I first got the adapter, I had to go through a 'web activation' process at dish.sling.com/activate. You enter a 7-digit code from the receiver to allow the adapter, and the receiver's S/N to 'web enable' the receiver. After entering the receiver S/N, clicking "Next" generates a SQL query error. Everything worked without a hitch with the original receiver, now the website is not playing nice.
primestar31
13,584
14,087
Beta Omicron Delta III
Are you sure the 722 receiver has a proper IP address from your router, and it's not in conflict with another device you are using? Could be two devices have the same IP, and they are fighting each other. That can happen from time to time in certain situations.
dwarren2
4,076
287
When I had a 722, sometimes the Sling would work and sometimes not. Usually, the red light would come back on after the over night reboot. So glad I have an HWS. Never had a problem with the built in Sling.
jlamb30
Jun 19, 2007
17
The only device on my network with a static IP is a desktop Mac; everything else is DHCP, so there is no IP address conflict.
DishAnywhere sees the receiver and adapter, I just can't watch anything... and the browser doesn't matter; I've tried them all.
primestar31
13,584
14,087
It is possible for DHCP to hand out the same IP address to two devices, so do not assume it can't happen. It depends on how long the lease is, and if you have portable devices that may be off-line at a time the lease expires. The IP address may then be handed out to another device. Then, the previous device with that address gets turned back on, and there you go, conflict!
Anyway, it's just a thought during brainstorming as to what could be going on. Gotta explore all possibilities.
3HaloODST
6,648
97
Earth
My 722k w/Sling adapter is just as reliable as my Hopper 2000s w/Sling adapters as well as my Hoppers w/Sling. As previously stated, Web Activation is a thing of the past. What do you see when you try to view Live TV via dishanywhere.com?
Bobby
Publican
70,004
25,637
Rohnert Park, CA
That says "Slingbox." Slingbox actually is not compatible with Dish Anywhere. "Sling Adapter" or "Hopper with Sling" is compatible. Are you using an Adapter or a Slingbox?
