YES Network is ancient history. The BIG Ten Network would require all 5 of those channels at noon on Saturday.Hmm maybe BTN and YES, that would be some coup.
It's looking more and more likely. But, where are the HD feeds?[/QUOT
That would be great if it were the BTN.....:
and why are they still adding SD Mpeg2. Isn't it time to start rolling out mpeg 4 SD to encourage the masses to start migrating?
..And Scott posted an announcement for something happening in 2 days on the front page...
Tick Tock, Tick Tock
Something is coming in just two days! Plus some exciting new features and some changes... What can it be? Stay tuned!
Are they done with the HD MPEG4 conversion yet?
No, but the point is to encourage adoption.
They're adding new HD in mpeg4 only. Why not SD also?
Just because some of the HD channels are not converted doesn't mean the SD has to be left as mpeg2.
What a great way to get better SD clarity in less SD space.
Its sounding more like Big 10 Network is coming
I agree. They can't make the SD conversion to mpeg4 until the come up with a plan to swap out all the mpeg2 receivers. I still think they will duplicate all the SD in mpeg4 after the new sat launches. There's a ton of old boxes out there.
I think it would be nice to build a m-peg 4 SD receiver FIRST then switch SD channels to MPEG-4I don't see why they can't push 622's to standard def dvr folks, there are still many advantages to this box over the 942 (or whatever the hell that model number was).
The same should go for the non-DVR HD boxes.
If they add a couple of fringe channels in MPEG4 SD some people that absolutely have to have those channels will switch to new receivers (and some will go to DirectTV I guess) which would make the swap a bit easier when they have to do everybody.
yes but they have all that expensive HD circuitry..Why? You can use the current MPEG4 receivers to view SD channels.
