My tuners are recording? during a signal test?
vurbano
On Double Secret Probation
23,815
104
Newport News, VA
WTF??? I cant watch anything on the HR20. When I select a channel it says Available tuners are recording. Select one of them to tune to "whatever channel I chose". Ealier I went to menu before this started and tried to look at signal strengths. It said that would interrupt a scheduled signal test which I guess is now going on? WTF???:confused:
vurbano
23,815
104
Newport News, VA
Ok I tried to view signal strength to interrupt the test and it does not interrupt it. Enough of this time to reboot.
TulsaCoker
579
Tulsa, Ok
It's called the double secret blind recording signal test. I thought everyone knew they were going on. :p
I don't know? i would just unplug the damn thing and start again.
JustinF
Oct 3, 2007
21
I also got that once. Make sure your not testing about 30 minutes before a scheduled recording. If you have to do a signal test, do it when your not recording anything for a few hours. I did get that message too. Just simply unplug and reboot your system. That should take care of the problem.
248 F1
Nov 12, 2006
7
This happened to me a number of times. I wasn't recording anything and I didn't ask for any signal test. Waiting a while didn't fix it, RBR did. Some type of glitch I guess.
vurbano
23,815
104
Newport News, VA
My hard drive only had 3% left, that could have had something to do with it.
GrogLikesBeer
Jan 20, 2006
19
Southwest Michigan
I just had this problem a couple of hours ago! I have 80% available. I did a RBR and everthing is good now. I did try to do a signal strength test within an hour of a scheduled recording, so maybe that's the trigger for this problem?
