Hi, I am new to this so please give me a little leeway.
I have 4 TVs in my house 2 are hooked directly to receivers and the other 2 are back fed from the receivers. I have a 625 and a 622 that gets HD for my plasma. Right now I have two cables coming into my house, let's call them cable A and cable B. Cable A goes to a diplexer, coming out of that one cable goes to my 622 and the other goes to one of my TVs. I think, now correct me if I am wrong, that they use the diplexer to back feed from another diplexer at the back of the receiver to my TV through channel 60. Now cable B is setup the same way as cable A but it goes to another TV and my 625. So there are 2 receivers each has 2 TVs hooked to it 1 directly and 1 back fed.
I found an example that closely resembles my current install except I only have 2 cables coming from the dish and I only have 1 "TV A 2" instead or 2:
http://www.solidsignal.tv/dishnetwork/DISH_Pro-DISH_Pro_Plus_Diagrams/DistributionExample3.pdf
I want to add another 622 for my new HD LCD but I am unsure how to do it.
Can I use a switch like a dp34 or dpp44 to connect cables A & B to and then from there go out to the diplexers then to my TVs and receivers?
If I use switches are they going to be fine with the HD content?
If I want to feed 3 dual tuner receivers then do I need to use 2 dp34 or dpp44s?
What is better to use in my situation dp34 or dpp44?
If I buy another 622 on eBay do I need to do anything to it or can I hook it right up?
Or is it just better to call dish and have them send a tech to do it?
Like I said I am new to this satellite TV thing and I am trying to learn so please any help you can give is appreciated. Also I am sorry if I messed up some of the acronyms.
