Installation Question
vegassatellite
3,319
174
Phoenix, AZ
So you are saying if I don't have a quad LNB then I can take 2 duals and 2 DP Splitters and run them to say....4 311's? and they will all work fine and pass DNS QA's?......... They are the same as a 21 switch?
No. The splitter will work with only a single orbital location. The reason is with multiple orbital slots, there are diseqc commands for LNB control and since a splitter won't process those, you will only see LNB A. The only circumstance this will work is single orbital, multiple tuner/receivers. I do these quite often when we have a Middle Easterner with a 625 and only a 61.5 dish.
DirectDishNet
1,052
Davenport Iowa
So it would be perfect for the guy who started this thread then. He has that wineguard single lnb wanting to get a dual lnb to one satellite. Wait........ He has a 222 receiver......... That will work for him then right?.........If so, I might PM him just to let him know.......
vegassatellite
3,319
174
Phoenix, AZ
To the receiver, it looks like two separate lines from the LNB. No voltage conflicts with any DP system and since its just one orbital, no LNB switching conflicts.
ddmo
Aug 18, 2007
8
OK. Thanks for the information. In order to make this work, does the LNB need to be a DP or will my existing LNB that came with my Winegard work? If my existing will not work, can someone recommend a DP single LNB that will fit my Winegard?
DDMO
volkodav
864
us
if you use the Holland splitter as shown earlier you should be able to make it work with existing LNB.
your existing LNB is rectangular at a bottom, and E* LNB is half oval i don't know if you can find LNB that will fit there, it is going to be easier to just get dish 500 with DPP twin and a separator
vegassatellite
3,319
174
Phoenix, AZ
The LNB has to be stacked. If his current LNB is a run-of-the-mill DirecTV LNB, it won't be stacked and he will have voltage conflicts. He needs a DP LNB. I think there are some stacked DTV LNBs he could use but I can't say for certain it will work. The DP LNB can be sawn with a hacksaw at the right places to fit into a square tube feed arm.
ddmo
Aug 18, 2007
8
I've been looking for a DP single LNB to purchase in order to replace the one I've got on the Winegard as you've suggested, but all I'm finding is DP dual lnb. Will this work? Any suggestions on where to find the DP Single LNB?
811 is driving me nuts!
LNB frequently needs replaced... Whats wrong?
