HR20 & Locals Question
donmigga83
I got direct installed this weekend, the wifey only wanted to have one satellite installed on the house. I was able to get an HR20 for my HD-DVR so that I can use the OTA function to get my locals in high def. Am I going to experience any problems beyond not getting my locals via sat if I just use the OTA antenna?
I hope this makes sense
Thanks!
Thanks!
You can still get your locals from the satellite if they are available in your area. That has nothing to do with using an ota antenna to get your locals.
Thanks!
It sounds like your wife only wants either the sat dish or the OTA antenna?
I'm confused. The only D* dish you should need would be the Slimline 5 LNB model. Or do you already have E* and the wife didn't want another dish besides the E* dish already installed?
Thanks!
Having the OTA antenna is actually the best way to go, you can have the dish and the antenna and get everything.
With the OTA you will get more channels than what D* can supply to you as far as OTA is concerned and you should not ever have to worry about losing an OTA signal, provided the network is on the air.
Also you can get a better signal from OTA , but D* is catching up quickly for those that have locals available thru D*.
Jimbo
Not knowing where the OP lives, I would venture to guess he has to get his SD locals from the 72.5 satellite. If that's the case, your SD locals will eventually move to one of the Ka satellites, so you'll be set up for all your locals-SD and HD, when DirecTV provides them.
You can use the HR20 for OTA if you do not get locals via satellite. So it also is a plus to have a backup and use an outdoor antenna to receive OTA in the event you have bad weather, despite the fact you get locals via satellite.
In 2008 DirecTV to add PBS HD.
Lin
