Hi everyone....with the advent of the new H/D channels, I thought I would share my recent experience....on the day of the "big event" I started to get
"searching for satellite" errors on several channels. Just the day before, I did
a signal level test, and all the sats. were in the hi-90's with a few 100's.
When I tested on Wed. all sats again showed similar readings EXCEPT tuner-2
readings which were in the toilet(30's-40's zero's)...this caused me to suspect
my HR 20-700 had a bad tuner line on line 2..this turned out to be false.
The real culprit as it turned out, was a faulty LNB assembly on the slimline dish.
which was just installed last Nov. Further research turned up some evidence
that these earlier dishes had a problem with bad LNB's. I noticed that the
replacement LNB assembly, has a curved head look much like the dish face itself, instead of the "old" one which had a straight across look. FWIW
