Tip & patient
magnigyro
326
2
Looking in "The list!" I would like to have the first 2 channels in AMC3 87W, tp:11715 H...
I receive cero quality in that tp. Rest of programming I get very good.
Any recommendations? Thanks...
What size dish and what receiver are you using? Does the transponder information on your receiver have the correct symbol rate (4857)?
Dish: 34" and I use a Pansat 2700a for testing, but I not sure about the tp information in the receiver, mmm:rolleyes:, I think today afer-job I must to edit a new tp with all the paremeters and scan that tp only.
Thanks...I´ll post the results
Finally getting them again after rebuilding my Fortec. Scan in via blindscan as 11716 4857 V
Understood and annotated!:) :up Thank you!
Dang... I STILL can't get Tip and Patient. One day I see them, the next day...gone. For a long time I was getting those channels with no problems.
Hello!
With 2700a all variants, editing & rescaning do not work..! Tip& Patient are mystery for me.
Guess? Yesterday I bring home the Pansat 2500a. It catched the tp I am looking for.
It was the first in blind scan: 11715 H 4857, 11735 V 8333,...
Quality measure is 30% aprox. but.... My screen continues black! Both channels are in list as channel 1 and channel 2, however no image appears.
It seems 2500a Pansat is good for testing (thanks Ice and everybody for your opinions).
Now I think I need a bigger dish...
Hello!
I dont watch those channels but in the past I found that transponder to have a very low signal compared to the others. I used that transponder and the Montana PBS transponder (also lower signal) to align my dish on 87W. You might need a little more than 30% quality to watch the channel.
Patient & Tip TV when they were on separate transponders use to blow the meter...now its much lower for some reason
Reckon AMC 3 is growing weak? Even Montana PBS is hard to tune in.
At last!
Yesterday night I saw that channels for first time!
What did it? I put a bigger dish:D 36" was big enough...:p
Now I´m getting wonderful 60% Q... The images clear and with no cuts...
Today in the morning all looks very good... Lung diseases in The Patience Channel..uff!:eek:
1.2m dishes available?
Dual LNB for this dish
