I recently acquired a new/used Satlook Digital NIT Meter/Analyzer. As you can see below, it is almost 5 years old.
The previous owner had bought it for one job, and after that put it on the shelf and was never used again. I know that to be true, because the cables were still sealed in the original bags.
I pulled the top off and checked the battery before I started and it was at 5.3 V. After charging for 32 hours it is still at 11.1 Volts.
When I try to turn it on without the AC hook-up it says error: battery empty.
Should I just continue to let it charge and hopefully bring it on up to 12 Volts?
Or should I try and find a battery for it now?
Second question:
The manual says to only operate it for a short time with the AC adapter plugged in and that it is not made for continuous use.
Do you owners operate yours with it plugged in for any long length of times?
Thanks for your help!
Here is a picture of the Date.
Second question:
