when cable goes digital will the 211 pick it up
gmitchell
62
Southeast Ohio
I have a 211 which is also hooked up to a cable feed for locals. I cannot see them on the 211 because they are analog. When the cable company makes the switch to digital will the 211 then be able to pick up the signal and show the channels?:confused:
lakebum431
17,007
4,900
Norris, TN
garys is exactly right. Almost all the time they are in QAM. Sometimes they are in the clear, but this is pretty unusual.
Tyralak
5,702
167
Secure, Undisclosed Location
You have an unusual cable company if they are going 100% digital. I don't know of any cable company doing that. Kind of a gutsy move. What company is this, and when do they plan on doing it?
gmitchell
62
Southeast Ohio
We have Suddensink er I mean Suddenlink. Not sure if they are going all digital but you can currently upgrade to a digital package so I assumed (I know what assume means:p) that they would go all digital in 2009.
Tyralak
5,702
167
There is no reason for them to go all digital in 2009. That only has to do with over the air broadcasters. Period. Has nothing whatsoever to do with cable or satellite. Cable can continue broadcasting analog until the end of time, and it would make no difference. So, you can rest easy on that count.
DishSubLA
5,450
1,416
Charter Cable in Long Beach California went all digital over a year ago--perhaps 2 years ago. There was going to be one more Charter going all digital. But, you are correct: with the exceptions counted on one hand, there just aren't any cable companies with 100% digital. even with 100% digital, they sometimes still have to use the analog for legacy customers.
Tyralak
5,702
167
Analog wastes bandwidth, they will be all digital eventually.
Oh, I'm sure they will. Just how long it will take is another matter. As cable is wanting to add more on demand, higher bandwidth internet, and more HD. They're also toying with increasing the spectrum they use to 1000 MHz or even higher. They're also working on switched video systems. All this along with analog reclaimation. Comcast locally has been moving more channels to digital, but they insist tehy won't go all digital anytime soon. We'll see.
dishrich
3,350
439
Springfield, IL
Actually, there IS a reason for ops to do this before 2/17/09 - & that is the fact that the fcc gave waivers on the "integrated security ban" (non cable-card digital boxes) to any cable ops that pledged to go all digital (NO analog whatsoever) before 2/17/09. By doing this, these same ops were able to use the cheaper non-cable-card boxes & save money when they did these all-digital conversions.
Bend Broadband & RCN Broadband of Chicago are 2 ops that come to mind that did this - granted, they are not anywhere near the size of a Comcast, but I'm sure other ops did the same thing. Bend Broadband even has this posted on their website as one of the reasons why they are going all digital by the end of this year.
Tyralak
5,702
167
Are we even talking about the same thing? I'm talking specifically about the "digital transition". I run into two huge misconceptions almost every day from customers that are worried that their TVs will no longer work. They A: Believe that all channels wil have to be HD and B: Think that everything inclding cable and satellite are affected. They aren't. Cable can continue offering an analog teir for as long as they want. It's a moot point with Satellite.
Look at the digital transition web site. The "digital changeover" has absolutely NOTHING WHATSOEVER to do with cable or satellite. OTA broadcasters are the only ones required to go all digital.
From the digital transition web site: "If you’re a cable or satellite subscriber, you aren’t likely to be affected by the DTV transition, but you may want to check with your cable or satellite provider if you have questions about your service"
Also from the "quiz" you take on their site: "Cable or satellite subscribers with televisions connected to a set-top box or otherwise wired to video services can continue to watch their favorite channels without interruption."
dishrich
3,350
439
Springfield, IL
ALL I was doing was answering your point about NO reason for cable to go all digital by 2009, & the fact that there is actually a reason for them to do so.
Does it have anything to do with the OTA digital transition - only to the point that the fcc gave an incentive date to cable ops, as I explained above, which just so happens to coincide with the 2/17/09 analog OTA cut-off.
Yes, I VERY much understand the difference between digital cable & the OTA digital transition, thank you - I only have to answer these type questions every day... ;)
