Remote Scheduling Question
warkovision
SatelliteGuys Guru
147
I did a search and didn't find much in this forum so......Is there a way to add time (similar to the recording options in the DVR's menu) to a scheduled recording done on the computer? I've just been selecting the subsequent program/s to cover myself, but is there another way?? I have HR-20 100s.
It uses whatever 'pad' time is set up for your receiver default. So if by default you end 2 minutes late, that's what you're remotely scheduled programs will do.
I know you can do a manual time record via the mobile (cellular) page, but am not sure if you can do that from the PC D* webpage. If nothing else, you can still go to m.directv.com from a PC to use that option. Someone can chime in if that option is available elsewhere that I'm not aware of.
There doesn't appear to be an option to add time to your recording when using the D* webpage.
You also cannot record an HD channel if using an OTA antenna for your locals, even though they are intergrated into your D* guide.
This is something that I hope they fix sometime soon.
Jimbo
1TB esata drive freezes on Direct TV
DirecTV gets FCC Permission to Test DirecTV 11
