Well I couldn't find an inexpensive dual c-band lnbf to replace my Geosat pro that got hit by lightning. Since I only watch one analog channel, and it is on a vertical transponder, I decided to try the B1SAT Stacked C-band LNBF from Sadoun.
I used a high frequency splitter with one port passing voltage to connect my Legacy C-band receiver, Mercury II, Sonicview 1000 and a Skystar II DVB card. My twinhan DVB card died with the Geosat pro LNBF.
Everything worked out well. A few observations:
I first adjusted the LNBF orientation to tune the one vertical analog channel.
Then I tried scanning with the Sonicview. At first it appeared that the vertical channels were being stacked instead of the horizontal. The horizontal channels came out at their normal frequency's, and the vertical channels came out +600. Of course I was expecting the opposite. The Mercury II will let me put in a low Lo and a high Lo so the channels all came out to their normal frequencies. So for kicks I tried the Mercury II set to single and a LO of 5750. The channles came out just as they did with the Sonicview. The horizontal were normal and the vertical were +600. Then I wondered if c-band being "high side injected" would make them come out this way? I don't suppose it matters, it WORKS!
I accepted having only vertical channels on the Legacy C-band receiver. I found that It will work likewise with only horizontal if you turn the LNBF 90 out of phase. The DVB devices didn't care, although I didnt notice how the frequencies came out. The channels still scanned in fine.:up
