Your in Quebec, so not only should you be getting signal on Nimiq 4, but your signal should be MUCH better...
What size dish do you have?
WooHooMy 76 cms Winegard dish arrived today and I just completed a quick check on my deck with a temporary mounting setup into my old 4700.
60s eh? The best I can get is 61% and it shifts from 57% to 61%All of the transponders on 82 come in with a lock. Even with the temporary and somewhat wobbly mounting I was getting signals in the 40's to high 60's for all transponders.
It would appear so. I've spent too much time today, on the roof, trying to squeeze out a few more % points on both sat. 82 w/ 76cm Winegard and sat. 91 w/ 55cm BEV dish.The signals here in Nashville are slightly higher than DaveFormula is getting in North Carolina so it probably indicates the footprint favors the west slightly which is what we expected.
i can lock all 32 transonders in Fisherville, VA on a 18 inch dish. TP10 is the lowest, TP3 is the highest. Signals are about 1% above the minimum, some are quite good like 30 and 32.
I still think I'm leaning towards cancelling BEV. Don't care to be their eternal guinea pig at this rate.
They actually go up at night. Provided that the sky is clear.Check your numbers on 82 at night and see if they go down due to the wobble...
Nimiq 2 has begun changing location; so it's no longer in the game at 82°
