I believe you previously had 119, 110 and 148 (for internationals).  You were probably using a SuperDish for 119 and 110 with 121 disconnected and a 300 for 148.  You now are trying to use the repoint kit for 119, 110 and 118.7.  If you are getting 58-63 on 119 you should try to re-peak your dish to get higher signals.  Double check what your skew, elevation and azimuth are for your area.  The skew DOES change if you add 129 which it sounds like you aren't using.
First, re-peak your dish to get the highest possible signal.  Try 119 first, then 110 and finally fine tune on 118.7.
Second, connect all cables to your 34 switch and run a check switch on your receiver(s).
Third, if you are still only receiving even transponders on 110 one of three things could be bad.  Try these steps to troubleshoot the problem.  Swap cables the the LNB with the 119 (port 2D).  Re-run check switch.  If you are still only receiving even transponders on 110, it is the LNB.  If 110 is good and you are only receiving even (or odd) transponders on 119, the cable is bad or the port on the switch is bad.  To check the switch swap cables on the switch and re-run check switch once again.  You can tell if it happens on only one input from the switch on your system info screen.
I hope this helps!  Don't mess around with 129, that is only for HD and you are using a 322 SD receiver.
