Raised the elevation 4 degrees as instruected and get a great signal on 119 but cannot pick up any signal on 110. skew is 123. Am I maybe to high of an elevation to catch the 110 signal with 123 skew?
thanks.
			thanks.
Cover the 119 lnb and see if you still have signal, you could have hit 119 with the 110 lnb.
have you read any of the posts, I'm not getting 110 at all. I'm getting 119 with a strength of 62. After several attempts moving the dish, I moved the 110 lnb connection to port 3 thinking maybe a bad port 1. now I get a signal strength of 10 on 129 without having moved the dish.What did you put on port 3? Are you getting 110? If your getting 119 on port 1, that is where it should be, and a decent signal on 110, then try going a little east, if no help there, try elevation changes while looking at 129 on signsl strength meter.
Dan
It sounds like you could have a switch problem. You can get an idea if you have an los problem by standing behind the dish and looking straight out at dish level, for 110 you observe the area just to the left of dish and look about 20 degrees higher then the elevation of the dish. If you see trees in that area you will know it could be a bad los.
Dan
That's the kind of advise I've been looking for, thank you. If I understand you right then, 110 will be higher in the sky than 119. If that is the case then I am either just mis-aligned or there is a problem with the switch, although I am more inclined with the alignment side.
Thanks.
Is he sure that he is not picking up 119 on the 110 lnb and 129 on the 119 lnb?
That's pretty slick119 will be higher than 110...I know it sounds goofy but when you work with multiple LNB's they go opposite what they are in the sky....so in standing behind the dish the LEFT LNB (119) will be higher than the right one
see attached...here what my D500 looked like a while back....with homemade 129 setup when DIsh didnt even sell a D1000 yet![]()
That's pretty slick
That's what I'm afraid I'm doing. The dishpointer site just doesn''t match the real world this time. If this is what is happening does that mean 110 and 119 are going to be available over the trees?
