Cables Question
SBacklin
35
I already have two lines going to each of the places where my dual tuner dvrs will go. How would they go about connecting the hd slimline 5 lnb dish to those?
Depending on what is installed, you may get a SWM and then use one wire to the DVR with a special splitter. The other would not be used. If not, you would have a multi switch installed (in your wiring closet) between the dish and the DVR's.
Well there was a multiswitch outside already that fed the old dual tuner dvrs from the old standard dish.
YUP!,
As others have demonstrated.......the SWM stuff is coming along.....your rig will work fine on what you have. Sometimes, because it is not broke is a good reason not to fix it.
A guess would be that the previous tenant / owner took the wb68 with him...good move on his part!
You will be OK!
Joe
