222 doesn't display picture on TV1
Andrewwski
1,205
4
Went to plug in TV1 into a 222 today. Previously only TV2 was being used - and that worked fine. Now we tried plugging in TV1 via component and it won't display a picture. It WILL show the channel bars, guide, etc, and there is sound, but it won't display the programming - the background is just solid black. Except once after a front panel reset, the first channel we tried was solid green, then all subsequent channels were solid black.
TV2 works fine. Everything on TV1 seems to work EXCEPT that the picture does not display. Which is kind of an issue.
Any suggestions, or do I have a faulty unit?
Do a hard reset, where you unplugg it then plug it back in. The 222 is one buggy SOB, if that don't fix it it's bad.
Reset it, unplugged it, did check switch, and everything else. Tried all channels - no luck. Finally convinced Dish that it was bad after they had me run through every test again, they're sending out a new one.
How far does a spotbeam go?
problem with 222 and sat at 77?
