DirecTV Slimline Transponder levels.
outerub
100
Michigan.
101 - All in the high 90's & 100's.
110 - All in the high 90's & 100's.
119 - All in the high 90's & 100's.
So I'm fine there.
14 @ 103 (conus)
1-8 95 86 91 80 89 79 88 74
9-16 89 77 89 90 92 82 N/A N/A
17-24 N/A N/A N/A N/A N/A N/A N/A N/A
25-32 N/A N/A N/A N/A N/A N/A N/A N/A
16 @ 103 (spot beam)
1-8 53 98 0 0 69 0 N/N N/A
9-16 N/A N/A N/A N/A N/A N/A 92 0
17-24 0 80 0 0 0 0 0 95
14 @ 99 (conus)
1-8 88 90 85 86 89 91 91 89
9-16 95 95 95 95 96 96 N/A N/A
16 @ 99 (spot beam)
1-8 0 0 0 0 0 0 N/A N/A
9-16 N/A N/A N/A N/A N/A N/A 71 97
17-24 0 0 98 97 95 92 72 81
Are these good ? ( I'm in Detroit - 48243 )
Are you having any problems with signal loss?
Those signals look fine to me, but I can't say for sure on the 99 and 103 spot beams.
No sir ... no problems with signal loss. I guess it's just the zeros on the 99 & 103 spot beam's that are bothering me. I just switched to an HR22 and was used to the 101 and all transponders in the high 90's. Why the zeros ? Why not "N/A" like the others ?
Many of the transponders on the 103 and 99 will show N/A or a low signal on the Spot Beam ones as your city is usually only on one transponder.
Your conus should be high as you have posted.
If you are having issues with channels not coming in, let us know, but all looks good on your end.
Some transpoders are NOT used as of yet, usually there are some not used on all sats, or not used in your area, many times if you have low signals , they are because it is trying to pick up signals from surrounding areas that you don't use.
Jimbo
Jimbo
Exactly the answer(s) I was looking for. Thank you. You are gentlemen all.
Regards,
UB. :)
