The problem with the Fortec 1.2m dish, is it's too heavy to conveniently fine tune the dish elevation setting. So here's my first solution, a pusher arrangement, to be used only in the tuning stage, to take the weight off the poor old operator and allow some micro adjustment.
Note the adjustable tension bolt at the bracket pivot point. [edit] There is a nylon washer on each side to promote controlled slippage and prevent metal-metal contact. [/edit] The bracket actually pivots on some 1/2" "dimples" in the steel, but this tension bolt holds the bracket dimples firmly in the appropriate hole, and provides a braking effect to prevent gravity "runaway". Regards to Anole for all the pics and advice he provided me on other such solutions.
