Problems in dual tuner setup??
thielepr
6
PR
I just upgrade to an 722 DVR HD dual tuner. I use a DP44. The thing is I not able to see the two television at the same time. If I'm see the TV1 the TV2 loose signal and it keep looking for signal. If a reset the receiver then I can see the TV2 but the TV1 go to look for signal.
try flipping the separator - if the problem follows to the other tuner your problem lies elsewhere. If the problem stays the same you have a bad tuner
My problem it that I can't see two TV at the same time. If TV1 is ok TV2 is looking for signal. If TV2 is ok TV1 is looking for signal
VIP 722 Newbie Remote question
Question re: Turbo HD and SD TV's
