2/9/2009 2:12am - Uplink Activity Report - 35 changes
D
DigiSAT Uplink Report
Guest
The first automated Uplink Report with click-able spotbeam maps. A big thanks to nelson61 for providing the data to create the maps that made this all possible!
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/9/2009 9:31am - 35 changes
Uplink Comparison Range: 02/09/2009 01:37A - 02/09/2009 02:12A
Channel Removals:
6800 - UP4 (NA) removed from Ciel-2 129W TP 15 Spotbeam ??
6801 - UPSD (NA) removed from Ciel-2 129W TP 15 Spotbeam ??
Channel Moves:
6312 - WLS [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6313 - WBBM [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6314 - WMAQ [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6315 - WFLD [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6316 - WGN9 [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6347 - KSTP [MPEG4 HD] moved from EchoStar5 129W TP 09 ConUS beam to Ciel-2 129W TP 13 Spotbeam 14 (A) (H)(St. Paul, MN)
6348 - WCCO [MPEG4 HD] moved from EchoStar5 129W TP 09 ConUS beam to Ciel-2 129W TP 13 Spotbeam 14 (A) (H)(Minneapolis, MN)
6349 - KARE [MPEG4 HD] moved from EchoStar5 129W TP 09 ConUS beam to Ciel-2 129W TP 13 Spotbeam 14 (A) (H)(Minneapolis, MN)
6350 - KMSP [MPEG4 HD] moved from EchoStar5 129W TP 09 ConUS beam to Ciel-2 129W TP 13 Spotbeam 14 (A) (H)(Minneapolis, MN)
7315 - WCHS [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Charleston, WV)
7316 - WOWK [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Huntington, WV)
7317 - WSAZ [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Huntington, WV)
7318 - WVAH [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Charleston, WV)
7319 - WQCW [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Portsmouth, OH)
7321 - WPBY [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Huntington, WV)
7322 - WOUB [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Athens, OH)
7324 - WKAS [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Ashland, KY)
7325 - WPBO [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Portsmouth, OH)
7860 - KSWO [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Lawton, OK)
7861 - KAUZ [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Wichita Falls, TX)
7862 - KFDX [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Wichita Falls, TX)
7863 - KJTL [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Wichita Falls, TX)
7865 - KKTM [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Altus, OK)
7910 - WBOYD [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Clarksburg, WV)
7911 - WDTV [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Weston, WV)
7912 - WBOY [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Clarksburg, WV)
7913 - WVFX [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Clarksburg, WV)
7915 - WNPB [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Morgantown, WV)
7929 - WVAW [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
7930 - WCAV [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
7931 - WVIR [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
7932 - WAHU [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
7933 - WHTJ [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
Channels in the system: 6505
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
TRANSPONDER CHANGES
DELETE Tp 9 EchoStar 5 129w ,8PSK SR 21500 FEC 2/3
DELETE Tp 12 EchoStar 5 129w ,8PSK SR 21500 FEC 2/3
DELETE TID 4015 Tp 15 SPOT XX Ciel 2 129w ,QPSK SR 20000 FEC 7/8
I wouldn't say ouch. ;) I'd say NICE! Regaining that CONUS space with the efficient use of spotbeams for locals.
We still have the following markets CONUS on 129:
Albuquerque, NM
Salt Lake City, UT
Wausau, WI
Nashville, TN
Los Angeles, CA
Sioux City, IA
San Angelo, TX
Abilene, TX
Get 'em out the way so more HD LILs can come online!
As soon as LA goes to spot, I guess I will have to make that big "move" back to the east coast in just a matter of a phone call myself...lol :)
I just hope Dish utilizes all this extra space for more HD, and it better be quicker than any SOON.
Albuquerque, NM
Salt Lake City, UT
Wausau, WI
Nashville, TN
Los Angeles, CA
Sioux City, IA
San Angelo, TX
Abilene, TX
I see them moved Nashville once already do you think there going to leave them CONUS?
Are there any HD spot beams on 129 that I could pick up in Charlottesville VA? I know Richmond is on 61.5.
I see they moved the SD Locals of the Wichita Falls, TX - Lawton, OK viewing market from Echostar 5 to Ciel-II. I'll have to check and see if it makes any difference on the video quality (which was fairly mediocre previously). They're still just MPEG-2.
The HD locals for the same viewing market are on E*12 at 61.5° -but they're missing KSWO channel 7 (ABC) in Lawton. I'm kind of wondering when they'll turn on that channel.
D
2/8/2009 5:42am Uplink Activity Report - 7 changes
2/11/2009 7:05am - Uplink Activity Report - 67 changes
