Does anyone know if the Richmond Va. HD locals have been moved from 61.5 to 129 spot beam? If so would that beam reach Charlottesville VA?
They should b on spot beam 39. They are in the table for Ciel 2 but not uplinked yet.
Spot beam 39: http://www.satelliteguys.us/thelist/database/Subscription/images/CIEL2_SB39.jpg
Thanks, If it is on 39 I'm within the area. Guess I need to just hang tight for the uplink. Thanks for the info.:up
I'm showing Richmond HD locals on 61.5, when did it change to 129? I show spot beam area 5 for these stations. You should be close enough to pick them up.
That reminds me, wasn't Richmond an Eastern Arc city thus 61.5? Has Ciel II changed it from Eastern/Western Arc to simply what gives the best line of site for certain areas?
I live in Richmond and when I went HD, they put a wing dish on 61.5 and removed my 129. He said the signal was stronger.
Not to burst anyones bubble, especially mine and bsakoff, but according to the list, Richmond locals will be on spot 40 not 39.
http://www.satelliteguys.us/thelist/database/Subscription/images/CIEL2_SB40.jpg
Here is the subscription list for 129:
SatelliteGuys.US - Subscription 129°W
Now I know green is good but if I am just outside of it but still within the yellow band, what does that mean?
Roanoke will be on Sp 39 in HD eventually so that is another option for us.
Roanoke supposed to go HD in March from what I recall.Looks like I'm in the yellow also. I guess I will have to check my signal strength for SP 40 when I get home. Roanoke will be stronger for sure, but who knows when that will go in effect...![]()
Are you at home? What is your signal strength on spot 40?
I am at home but I don't think either spot or transponder is lit up yet on Ciel 2.
Sp 39 will be on TP05 and Sp 40 will be on Tp14 but right now I get no signal lock on either transponder.
So do you think your in range? I'm dying with this sd garbage lol.Tonight I am now getting 24-26 on TP 14 and 46-50 on TP 05.
