2/19/2009 1:57pm - Uplink Activity Report - 64 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/19/2009 1:57pm - 64 changes
Uplink Comparison Range: 02/19/2009 01:26P - 02/19/2009 01:57P
Channel Removals:
281 - BIO (NA) removed from EchoStar11 110W TP 05 ConUS beam
281 - BIO (NA) removed from Echostar6 72.7W TP 03 ConUS beam
282 - HISTI (NA) removed from EchoStar11 110W TP 01 ConUS beam
282 - HISTI (NA) removed from Echostar6 72.7W TP 11 ConUS beam
283 - HMC (NA) removed from EchoStar11 110W TP 01 ConUS beam
283 - HMC (NA) removed from Echostar6 72.7W TP 01 ConUS beam
284 - EDRAM (NA) removed from EchoStar11 110W TP 06 ConUS beam
284 - EDRAM (NA) removed from Echostar6 72.7W TP 21 ConUS beam
285 - EWAM (NA) removed from EchoStar11 110W TP 21 ConUS beam
285 - EWAM (NA) removed from Echostar6 72.7W TP 07 ConUS beam
286 - ENCOR (NA) removed from Echostar6 72.7W TP 03 ConUS beam
286 - ENCOR (NA) removed from EchoStar7 119W TP 14 ConUS beam
287 - ENCRW (NA) removed from EchoStar11 110W TP 15 ConUS beam
287 - ENCRW (NA) removed from Echostar6 72.7W TP 21 ConUS beam
288 - EWSTN (NA) removed from EchoStar11 110W TP 15 ConUS beam
288 - EWSTN (NA) removed from Echostar6 72.7W TP 09 ConUS beam
289 - EACTN (NA) removed from EchoStar11 110W TP 05 ConUS beam
289 - EACTN (NA) removed from Echostar6 72.7W TP 09 ConUS beam
290 - EMYST (NA) removed from EchoStar11 110W TP 01 ConUS beam
290 - EMYST (NA) removed from Echostar6 72.7W TP 09 ConUS beam
291 - ELOVE (NA) removed from EchoStar11 110W TP 16 ConUS beam
291 - ELOVE (NA) removed from Echostar6 72.7W TP 21 ConUS beam
292 - BITV (NA) removed from EchoStar11 110W TP 02 ConUS beam
292 - BITV (NA) removed from Echostar6 72.7W TP 23 ConUS beam
357 - ENCOR (NA) removed from Echostar6 72.7W TP 03 ConUS beam
357 - ENCOR (NA) removed from EchoStar7 119W TP 14 ConUS beam
358 - ENCRW (NA) removed from EchoStar11 110W TP 15 ConUS beam
358 - ENCRW (NA) removed from Echostar6 72.7W TP 21 ConUS beam
359 - EWSTN (NA) removed from EchoStar11 110W TP 15 ConUS beam
359 - EWSTN (NA) removed from Echostar6 72.7W TP 09 ConUS beam
360 - EACTN (NA) removed from EchoStar11 110W TP 05 ConUS beam
360 - EACTN (NA) removed from Echostar6 72.7W TP 09 ConUS beam
361 - EMYST (NA) removed from EchoStar11 110W TP 01 ConUS beam
361 - EMYST (NA) removed from Echostar6 72.7W TP 09 ConUS beam
363 - ELOVE (NA) removed from EchoStar11 110W TP 16 ConUS beam
363 - ELOVE (NA) removed from Echostar6 72.7W TP 21 ConUS beam
365 - STARZ (NA) removed from Echostar6 72.7W TP 07 ConUS beam
365 - STARZ (NA) removed from EchoStar7 119W TP 14 ConUS beam
367 - SEDGE (NA) removed from Echostar6 72.7W TP 07 ConUS beam
367 - SEDGE (NA) removed from EchoStar7 119W TP 14 ConUS beam
368 - SCINE (NA) removed from Echostar6 72.7W TP 07 ConUS beam
368 - SCINE (NA) removed from EchoStar7 119W TP 14 ConUS beam
370 - SBLCK (NA) removed from Echostar6 72.7W TP 07 ConUS beam
370 - SBLCK (NA) removed from EchoStar7 119W TP 14 ConUS beam
371 - SK&FM (NA) removed from Echostar6 72.7W TP 07 ConUS beam
371 - SK&FM (NA) removed from EchoStar7 119W TP 14 ConUS beam
372 - EDRAM (NA) removed from EchoStar11 110W TP 06 ConUS beam
372 - EDRAM (NA) removed from Echostar6 72.7W TP 21 ConUS beam
373 - EWAM (NA) removed from EchoStar11 110W TP 21 ConUS beam
373 - EWAM (NA) removed from Echostar6 72.7W TP 07 ConUS beam
375 - STRZW (NA) removed from EchoStar11 110W TP 15 ConUS beam
375 - STRZW (NA) removed from Echostar6 72.7W TP 03 ConUS beam
376 - STZC (NA) removed from EchoStar11 110W TP 15 ConUS beam
376 - STZC (NA) removed from Echostar6 72.7W TP 07 ConUS beam
377 - MAX-E (NA) removed from Ciel-2 129W TP 27 ConUS beam
377 - MAX-E (NA) removed from EchoStar3 61.5W TP 22 ConUS beam
378 - STARZ (NA) removed from Ciel-2 129W TP 30 ConUS beam
378 - STARZ (NA) removed from EchoStar3 61.5W TP 02 ConUS beam
7332 - WRCB (NA) removed from Echostar12 61.5W TP 03 Area 7 beam(Chattanooga, TN-NBC)
7552 - KHAS (NA) removed from Echostar12 61.5W TP 13 Area 8 beam(Hastings, NE-NBC)
7731 - WCTI (NA) removed from Echostar12 61.5W TP 07 Area 5 beam(New Bern, NC-ABC)
7734 - WFXI (NA) removed from Echostar12 61.5W TP 07 Area 5 beam(Morehead City, NC-FOX)
8171 - KTXS (NA) removed from Echostar12 61.5W TP 07 Area 3 beam(Sweetwater, TX-ABC)
9248 - WOLF (NA) removed from Echostar12 61.5W TP 07 Area 6 beam(Hazleton, PA-FOX)
Channels in the system: 6495
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
I guess they are removing the channels they put there (but never made available) a few weeks ago. Doesn't mean we are losing anything, just that Dish Network is taking back something that wasn't available. Many speculated when Dish uplinked these that they were rearranging the channel lineup (which is much in need of a clean up).
Well I will say it a thousand times, I wish Dish Network will 'tidy up' the arrangement of the channels. Having channels duplicated and scattered around, even if you set your favorites...is still hard to navigate sometimes.
Like a true SatelliteGuy, that darn rabbit never gives up trying to get new HD
I noticed his avatar the other day, but I am not getting my hopes up this time until around the time of that Dish Network Team Summit Convention event they have in the Spring, that's when I think the new national HD will appear. They gotta have something to talk about at that convention right..? ;)
They should just do as DIRECTV does and if there is an hd version of any channel it takes the place of that channel and the sd version goes away. Then there is no need to have hundreds of mirror channels cluttering up the guide . I have a slew of channels locked out in my locks menu to clean up all the clutter.
The only problem I see with that is sometimes you can lose signal on 1 sat knocking out that channel. With both still listed, you could watch the other in the downtime.
I don't have this happen unless the channel itself goes out. Now when the crappy echostar 5 sat at 129 was the only one up there , I had a lot of hd channels drop out . So much so that I had the 61.5 sat added to use instead of the 129 lnb. I now have all 4 sats in my switch matrix and no more drop outs .
That would be true if it wasn't for Stretch-O-Vision. I have all the SD versions locked out, except for Scripps and Turner channels. Sometimes, I just can't handle the distortion and switch down to the SD.
D
2/19/2009 4:01pm - Uplink Activity Report - 1 change
D
2/18/2009 1:52pm - Uplink Activity Report - 71 changes
