Sorry if this has been discussed but I don't have a coax on my tv2. To convert the coax to components, will a vcr work? the Dish installer suggested using an RF Converter but those convert from component to coax not the other way around.
My 722 has composite out for TV2 in addition to the coax.Sorry if this has been discussed but I don't have a coax on my tv2. To convert the coax to components, will a vcr work? the Dish installer suggested using an RF Converter but those convert from component to coax not the other way around.
What TV do you have that does not accept a coax?
-Ken
Why cant you just Use the Composite TV2 and hook it to your TV or Monitor? How are you hooking up your VCR to the TV if the TV doesn't have composite or coax inputs?
I guess so.Op probably doesn't want to run the needed cables to another room of the house and is wanting to use existing coax run.![]()
The HD DVR ALSO has Composite TV2 Option.( Yellow,Red,White , TV2) I don't think you need a Tuner to use that. But You would have to buy and Run these cables, Or Buy a TV that has a Coax.Sorry, I wasn't very clear. I have a HD DVR Tuner (not sure of the model) from Dish and want to use my TV2 option in another room. Unfortunately, the Dish system uses the existing coaxial cable the my home was wired with to transit the signal over either channel 60 0r 73 to the second room and the TV I want to use does not have a built in tuner. Bottom line, I would like to be able to watch TV2 on my tunerless TV without having to use a VCR or something with a built in tuner. Is there a small inline device that would demodulate channel 60 or 73 from the coax? My TV only has S-video, composite and HDMI inputs.
