We have a new Sharp LCD HDTV hooked up to amplified rabbit ears. Reception is spotty and unreliable. This TV is downstairs. By contrast, the analog TVs upstairs (with HDTV adapters and amplified rabbit ears) have reasonably good reception and we have no complaints with those.
I'm thinking of installing an antenna in the attic (third story), dedicated to the problem TV on the first floor. I was looking at the Winegard MS-2000, but then noticed my desired channels (all <=30 miles) cluster as follows:
Six channels cluster between 4 degrees and 25 degrees;
Four cluster between 303 degrees and 306 degrees;
One is at 218 degrees, but reception to this channel isn't critical.
Do you guys think I should go the Omni or Directional antenna route?
If directional, which antenna models do you recommend?
In case it's helpful, attached is a copy of TV Fool output for my location. Thanks you experts are most impressive!
