Need Satelliteguys help with readings on AMC2/4 (101W)
SatelliteAV
6,486
186
Roseville, CA
TP Frequency 11860 was switched over from AMC4 to AMC2 last week. We are working with several broadcasters who are located in that MUX and are experiencing very low signal levels.
Would a few of you SatelliteGuys provide Signal Quality readings on these TPs?
11708 - SQ
11822 - SQ
11860 - SQ
11983 - SQ
12020 - SQ
12120 - SQ
12160V S/R 30000 Test Signal - SQ
here goes
Minneapolis, MN
30" Winegard Dish
Sadoun dual LNB
Coolsat 5000
meter minimum 63
max is 82-85...usually max is 82...to be uber strong it maxes at 85
11708 - SQ 82
11822 - SQ 85
11860 - SQ 69
11983 - SQ 79
12020 - SQ 85
12120 - SQ 75
12160V S/R 30000 Test Signal - SQ 69
same setup but a Visionsat IV-200 now as receiver
11708 - SQ 88
11822 - SQ 94
11860 - SQ 55
11983 - SQ 86
12020 - SQ 94
12120 - SQ 79
12160V S/R 30000 Test Signal - SQ 45
Don't know whether my readings will be of much help, considering that my LNB for AMC4 is 6 degrees off-centre on a Star Choice 60e dish, but here goes:
Pansat 3500SD
11708 - SQ - 90
11822 - SQ - 90
11860 - SQ - 30
11983 - SQ - 30-45 (very jumpy)
12020 - SQ - 75
12120 - SQ - 45
12160V S/R 30000 Test Signal - SQ - 14-20
AMC4
Southwestern Ontario Canada
33" fortec
sat radar lnb
Sonicview 360E
11708 - 0
11822 - 99
11860 - 35
11983 - 98
12020 - 98
12120 - 41
12160V-23
Andy
on 11708 (KUIL) try and drop the frequency a few to 11706 or 11705...it should pop in. (on the Visonsat I needed to be on 11705 for it to stay locked)
Dish pointed at 101W.
Coolsat 6K
11708 - SQ - 90
11822 - SQ - 93
11860 - SQ - 86
11983 - SQ - 87
12020 - SQ - 93
12120 - SQ - 87
12160V S/R 30000 Test Signal - SQ - 70, sometimes flaps from 69 to 86.
Memphis, TN
Diamond 9000HD
39" Digiwave
11708 - SQ - 75
11822 - SQ - 86
11860 - SQ - 70
11983 - SQ - 79
12020 - SQ - 84
12120 - SQ - 72
12160V S/R 30000 Test Signal - SQ - 62
11708 - SQ 90%
11822 - SQ 98%
11860 - SQ 74%
11983 - SQ 98%
12020 - SQ 98%
12120 - SQ 82%
12160V S/R 30000 Test Signal - SQ 74%
These were all taken using my Twinhan card that is slaved off my Fortec box in zip 62040.
Denver, Colorado
Traxis 3500, Invacom QPH-31, 36" Geosat Pro
11708 - 78
11822 - 83
11860 - 70
11983 - 79
12020 - 81
12120 - 72
12160V S/R 30000 Test Signal - 66
Los Angeles, CA - Pansat 3500SD - 1.2 Meter
11708 - SQ - 90
11822 - SQ - 99
11860 - SQ - 63-75
11983 - SQ - 99
12020 - SQ - 99
12120 - SQ - 89
12160 - SQ - 70
Measured on a Fortec Lifetime Ultra and a T-90 in Canby, Oregon 8:00 AM March 19
11708 - SQ 73
11822 - SQ 99
11860 - SQ 47
11983 - SQ 88
12020 - SQ 89
12120 - SQ 70
12160V S/R 30000 Test Signal - SQ 39
Bob
Southwest Missouri, USA
Clear skies
90 cm 3ABN/Techsat TrackerII/Visionsat IV-200
11708 - SQ 82
11822 - SQ 90
11860 - SQ 50
11983 - SQ 88
12020 - SQ 92
12120 - SQ 82
12160V S/R 30000 Test Signal - SQ 34
Measured on a GeoSatPro DVR 1100c and a dual mini-LNB Glorystar 90cm in Canby, Oregon 10:00 AM March 19
11708 - SQ 75
11822 - SQ 90
11860 - SQ 31
11983 - SQ 60
12020 - SQ 85
12120 - SQ 55
12160V S/R 30000 Test Signal - SQ couldn't get the receiver to recognize or show S/Q on this TP
Bob
Measured on a GeoSatPro DSR 100c and a dual output SL2 mini-LNBF and a GeosatPro 90cm dish in a Glorystar setup NW of St. Louis, MO. :)
11708 - SQ 75%
11822 - SQ 95%
11860 - SQ 60%
11983 - SQ 85%
12020 - SQ 90%
12120 - SQ 70%
12160V S/R 30000 Test Signal - SQ 65%
Here's what I got. First column is with a Fortec Mercury II, second with a Visionsat IV200. Both hooked to a 90CM ChannelMaster dish with Hughes c120 LNB. It was a beautiful clear day today at 13681!
11708 - SQ 72 89
11822 - SQ 83 99
11860 - SQ 56 48
11983 - SQ 70 85
12020 - SQ 84 94
12120 - SQ 67 84
12160V S/R 30000 Test Signal - SQ 57 52
Andy
Thanks Ice.I changed it this morning but only got it up to about 21.The others that I got into the 90's on were down about 25 to 30 points this morning thou.Not sure whats up with that so I'll try again late in the evening and check out kuil again.Should wait thou since I played with it today and its off the arc again after 15% each way past due south lol.Gotta stop playin with it.
Living Room Main Box - CNX MINI
11708 - SQ - 95
11822 - SQ - 90
11860 - SQ - 95
11983 - SQ - 85
12020 - SQ - 95
12120 - SQ - 92
12160V S/R 30000 Test Signal - SQ - 76
Bedroom Box - Fortec Star Dynamic
11708 - SQ - 80
11822 - SQ - 85
11860 - SQ - 80
11983 - SQ - 75
12020 - SQ - 85
12120 - SQ - 80
12160V S/R 30000 Test Signal - SQ - 60
Out Building Shop Box - Fortec Star Lifetime Classic NA
11708 - SQ - 79
11822 - SQ - 85
11860 - SQ - 76
11983 - SQ - 82
12020 - SQ - 83
12120 - SQ - 80
12160V S/R 30000 Test Signal - SQ – 50
On 80 CM Fortec Star, Invacom QPH-031
Mineral Wells, West Virginia
Latitude: 39.2°N
Longitude: 81.5°W
Brothers Viewsat Max HD in Clarksburg WV Readings
11708 - SQ - 95
11822 - SQ - 96
11860 - SQ - 75
11983 - SQ - 90
12020 - SQ - 95
12120 - SQ - 95
12160V S/R 30000 Test Signal - SQ – 65
On WS9036 WS International 90 CM Dish Invacom QPH-031 90 CM
Longitude: 80° 20' 41" W Latitude: 39° 16' 50" N
Neighbors Coolsat 6000 Premium
11708 - SQ - 86
11822 - SQ - 90
11860 - SQ - 87
11983 - SQ – 90-93 %
12020 - SQ - 90
12120 - SQ - 85
12160V S/R 30000 Test Signal - SQ – 60
On Fortec Star 80 CM TechSAT TRACKER II+ LNB
Latitude: 39.1°N
Longitude: 81.2°W
Network Feeds?
GEOSATpro C2 LNBF Arrived Today
