I don't think Shreveport will ever be launched in HD.
I do miss the local Shreveport news, but sure are lovin the HD.... and almost everything is in HD even the Dallas local news. It was worth the move :clap: come on in the water is fine Still Not sure I want to get in the water yet. As I'll loose my OTA Guide Info.
Check TP 11 on 129..you should be in the beam. That's Lafayette, LA (ABC, CBS, FOX). Also you might have a few other choices. Post your signal strengths on 129 transponders 1 - 16 and I'll determine what you can get. Make sure you give it a few seconds to lock onto the transponder. Only post the ones where the the display says "Spotbeam" and shows locked on 129.
Baton Rouge will be on TP 9 on the same beam as Lafayette, LA but they about another month or two off from being available.
Thanks for helping. Here are the readings. I only posted locked spotbeams. If not posted, it is 0
This is all 129.
TP
1 43
3 28
9 26
11 37
14 37
16 17
1 - SB 37 - Nothing yet
3 - SB 37 - Fort Smith, AR (unavailable as of this post)
9 - SB 42 - Baton Rouge, LA (unavailable as of this post)
11 - SB 42 - Lafayette, LA (available - FOX, ABC, CBS only - no NBC in DMA)
14 - SB 38 - Nashville, TN (available - all 4)
16 - SB 38 - Memphis, TN (unavailable)
Surprised you don't see TP 13 of SB 38.
But as you see, you do have two choices.
Yeah, TP13 gives me a strength of 6 and does not lock. I didn't include it.
it would seem to me that the Nashville (tp14=37) signal should be less than Memphis (tp16=17).
I'm not at all clear what the 129 spotbeam readings mean. I'm showing spotbeam signal readings that must be empty or place holders. Portland and Seattle are on 110, and Yakima (129 tp 11) is the only one that appears to be real.
Why does it take so long for the spot beams to lock? On 110/119, I get signal almost immediately. Takes like 10 seconds to get Spotbeam 14 to come up. Why is that?
So, what kind of address would I give them to 'move'? I suppose I will tell them I have leased a house with a dish in place and moved my receivers. Just want to know how to derive the address.
Thanks A TON for all the help. You guys are great. Hopefully, I can return the favor some day.
Chris
: Atlanta channels.transponder 31, it should change to say spotbeam on the signal meter. You said earlier in this thread you had a signal of 28 on that beam, when I suggested Dallas, which is good enough for reception except maybe during heavy downpours.
There still might be hope.. Spotbeam 37 on 129 seems to cover Shreveport. It consists of TP 1 and TP 3. TP 3 is slated for Fort Smith, AR. Nothing on TP 1 yet...they might mirror Little Rock, AR but they are on EA already..and most of the mirrored markets are already listed in the uplink. But of course if you want locals in HD you'll have to get a temporary job in another city![]()
