PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
Window of opportunity to download:
Friday, April 10, 2009 11:00PM - 2:30AM ET
Saturday, April 11, 2009 11:00PM - 2:30AM ET
NATIONAL CANDIDATES:
HR21-200, R22-200, HR21-700, HR23-700
* Medium Risk Download
HR21-100, HR22-100, R22-100
Improvements
* Under the hood
* UI polishing
Fixed
* Occasional SFSS on Tuner 2 (searching for satellite signal) (-100 models only)
Notes
* You will lose your guide cache when going between previous CE's and this release.
* Widget Keyword may be reset and need to be re-entered to restore functionality. (Keyword search WIDGETSON)
* When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number.
Improvements
* Under the hood
* UI polishing
Fixed
Notes
Previous Cycle Notes:
New features
- 02 - New System Test and Info Screen
- 02 - {FORMAT} button enabled while playing 1080p content
Improved/Updated
- 01 - Recording robustness
- 01 - Support for more actors in programs
- 01 - Video issues playing back 1080p content at lower resolutions.
- 01 - Audio drops/out of synch after using trickplay and jumping to bookmarks on MPEG4 HD channels.
- 01 - Mediashare:
- Issues with only 1 photo in the photo playlist.
- Incorrect duration for large audio files.
- Other Mediashare fixes/tweaks.
- 01 - Misc. UI fixes/tweaks
- 01 - XM channels:
- Loss of background image
- No music info when exiting screensaver
- 02 - Corrected missing HD icon in My Playlist
- 02 - Improved HD icon with manual recordings
- 02 - Improved consecutive channel ups
- 02 - MediaShare: Fixed aspect ratio
- 02 - MediaShare: Improved Trick Play bar
- 02 - Improved stability with interactive channels
- 03 - Fixed occasional searching for satellite signal when tuning HR20-700
- 03 - Fixed video freeze up when using Trick Play HR20-700
- 03 - Fixed loss of background when using Interactive Applications
- 03 - Improved Interrupted Manual Recording Display
- 04 - MediaShare:
- 04 - Lockups when viewing pictures.
- 04 - Lockups when viewing streaming video.
- 04 - Aspect ratio changes when streaming video.
- 04 - Set Top Box tunes to channel 201 after software download.
- 04 - Audio Synching on HD recordings after jumping to bookmarks.
- 04 - Parental Control lock causing DOD Homepage viewing issues.
- 04 - DOD program search program info takes you to wrong screen.
- 04 - "Sluggish" UI behavior – especially in DOD navigation.
- 04 - QuickMenu/On Demand addition options added.
- 04 - Added remote codes.
- 05 - MediaShare: Improved display for songs/titles
- 05 - Fixed Blue flash when performing Trick Play on live TV
- 05 - Fixed Keep at Most setting
- 05 - OSD improvements for PPV
- 05 - OSD improvements for deleting in To Do List
- 06 - Searching for satellite signal HR21-700
- 06 - System Test Issues
[*]Does not complete
[*]Dish Pointing Failure
- 06 - Single Frame Forwarding
- 06 - Updated MediaShare failing when accessing pictures and music
- 06 - Loss of Video when switching to HDMI
- 06 - Interactive Applications
- 06 - Loss of background when accessing Widgets
- 06 - Improved on screen display for pay-per-view
- 06 - Additional System Test improvements
- 06 - 1080p on screen display
- 07 - Screen background issues
- 07 - UI Polishing
- 07 - Stability
[*]08 - System Test: fixed Dish Pointing failure
[*]08 - System Test: additional improvements
[*]08 - Under the hood
Notes
- You will lose you guide cache when going between national and this release
- When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
- Please make sure to first attempt to tune to an OTA channel before running an OTA signal strength system test
- 06 - Widget Keyword will be reset - Do a search for WIDGETSON to re-enable
- 07 - Widgets are active again with this release
- 07 - Guide cache may be lost when downloading
[*]08 - Widget keyword may be reset
[*]08 - Guide cache will be reset
